LabWindows/CVI
pixel perfect sizing and relocation
I'm trying to refine a library I've made for looking up (and setting) panel locations and sizes.  I've got some bug somewhere in my frame thickness lookup, as it's returning a value of 8, whereas in my UIR, the default value is 3.  I can't find the discrepancy of 5 pixels (assuming it's a Windows 10 theming issue?).
My lookup function:
Rect GetPanelBounds(int panel)
	Rect bounds = {0};
	int measurement;
	// look up the panel location
	GetPanelAttribute(panel, ATTR_LEFT,		&bounds.left);
	GetPanelAttribute(panel, ATTR_TOP, 		&bounds.top);
	// look up the panel size
	GetPanelAttribute(panel, ATTR_HEIGHT, 	&bounds.height);
	GetPanelAttribute(panel, ATTR_WIDTH, 	&bounds.width);
	// for information only
	GetPanelAttribute(panel, ATTR_MENU_HEIGHT, &measurement);
	// add the frame borders to width
	GetPanelAttribute(panel, ATTR_FRAME_ACTUAL_WIDTH, &measurement);
	bounds.width += (2 * measurement);
	// remove a frame border from left location
	bounds.left -= (1 * measurement);
	// add the frame borders to height (includes menu)
	GetPanelAttribute(panel, ATTR_FRAME_ACTUAL_HEIGHT, &measurement);
	bounds.height += (2 * measurement);
	// remove a frame border from top location
	bounds.top -= (1 * measurement);
	// add the titlebar to height
	GetPanelAttribute(panel, ATTR_TITLEBAR_ACTUAL_THICKNESS, &measurement);
	bounds.height += measurement;
	// remove a titlebar from top location
	bounds.top -= measurement;
	return bounds;
And my setter function:
void SetPanelBounds(int panel, Rect bounds)
	int measurement;
	// remove the frame borders from width
	bounds.width -= (2 * measurement);
	// add a frame border to left location
	bounds.left += (1 * measurement);
	// remove the frame borders from height (includes menu)
	GetPanelAttribute(panel, ATTR_TITLEBAR_THICKNESS, &measurement);
	bounds.height -= (2 * measurement);
	// add a frame border to top location
	bounds.top += (1 * measurement);
	// remove the titlebar from height
	bounds.height -= measurement;
	bounds.top += measurement;
	// apply the panel size
	SetPanelAttribute(panel, ATTR_HEIGHT, 	bounds.height);
	SetPanelAttribute(panel, ATTR_WIDTH, 	bounds.width);
	// set location
	SetPanelAttribute(panel, ATTR_LEFT,		bounds.left);
	SetPanelAttribute(panel, ATTR_TOP, 		bounds.top);
(3,012 Views)
Accepted by topic author ElectroLund
Wow, I sure made that overly complicated.  After reading more in the SW manual, I see that ATTR_TOP and ATTR_LEFT for panels are relative to the panel excluding the titlebar.  Therefore, it's much simpler to completely disregard all other dimensions when Getting and Setting.
So a new set of functions looks like this and I get good pixel-perfect results:
	Rect bounds = {0};
	return bounds;
	SetPanelSize(panel, bounds.height, bounds.width);
	SetPanelPos(panel, bounds.top, bounds.left);
(2,989 Views)
