LabWindows/CVI
plotstripchart in tabpanels
hello,
I am using tabpanels  and I have have stripcharts on them. On a tab I have two or three tabpanels and when I want to use the function plotstripchart, I cannot plot on different tabpanels.... I can only use this function as many times as i want but only on the same tabpanel otherwise I have this error message :
NON-FATAL RUN-TIME ERROR:   "test(2).c", line 554, col 21, thread id 0x00000F5C, function id 1:   Library function error (return value == -10 [0xfffffff6]). The control is not the type expected by the function
and here is my code :
 GetPanelHandleFromTabPage (panelHandle, PANEL_TAB_WEAK, 0,
                           &tabpanelHandle);
       PlotStripChart (tabpanelHandle, TABPANEL_CHARTX, dataX, NUM_VALUES*4, 0, 0, VAL_DOUBLE);
      PlotStripChart (tabpanelHandle, TABPANEL_CHARTY, dataY,NUM_VALUES*4, 0, 0, VAL_DOUBLE);
//these two guys above are working well but the one following not :
PlotStripChart (tabpanelHandle, TABPANEL_0_EOM_VOLTAGE, dataX,NUM_VALUES*4, 0, 0, VAL_DOUBLE);
Thanks in advance
Estelle
(3,638 Views)
Hello Estelle,
tabPanelHandle is the handle for the first tab page on your tab control. If the stripchart is located on another tab page, you should get also a handle for this other tab page, using the function GetPanelHandleFromTabPage. If the control EOM_VOLTAGE is located on the tab page with index 1 (2nd page), use the following code:
GetPanelHandleFromTabPage (panelHandle, PANEL_TAB_WEAK, 0, &tabpanelHandle);     // First page on the tab control.
GetPanelHandleFromTabPage (panelHandle, PANEL_TAB_WEAK, 1, &tabpanelHandle);     // Second page on the tab control.
Success,
Wim
(3,635 Views)
I think it will help ......
estelle
(3,634 Views)
