LabWindows/CVI
popup menu and icons
I'd like to build a popup menu with icons inside (see the attached example image). Does someone know a way to obtain it ?
Thank you !
(3,449 Views)
You can easily use the Windows SDK MessageBox function to display a dialog box with various icons like an exclamation mark, a question mark, etc.
Include windows.h at the top of your .c file.
MessageBox(NULL,"Message","Title",MB_ICONQUESTION);
I didn't see any attachment to your post.
See the attached example for more uses of MessageBox.
(3,443 Views)
My post didn't show an attachment either. Here's a second attempt to attach my project. It may have been deleted after I got an error posting my first response.
(3,440 Views)
I'd like to create a menu with different icons and not a window. Now I try to re-post the example image
(3,438 Views)
Hi Massimiliano,
I am not sure if this is going to answer your question, but try and have a look at this document. Seem sto be pretty close to what you need to do...
http://digital.ni.com/public.nsf/websearch/D6CB66DE5819897F86256C320041A77D?OpenDocument
AlessioD
(3,413 Views)
