LabWindows/CVI
prevent windows from opening a window
by adding a memory-stick to the system (usb-stick) windows starts to open an
explorer window that shows the contents of the stick. Is there anyway to
keep windows from opening this window from CVI f.e. by capturing a windows
message ?
Norbert
(3,765 Views)
Hey,
Have you tried to disable the Shell Hardware Detection service on windowsxp ?
(3,742 Views)
> windowsxp ?
No, not yet, can i do this programmatically ?
"captainst" <x@no.email> schrieb im Newsbeitrag
news:1164550217928-445538@exchange.ni.com...
> Hey,
> windowsxp ?
(3,733 Views)
Thanks for your tip captainst,
that's how i got it to work:
sprintf(command_str,"command.com /c net stop ShellHWDetection");
status = LaunchExecutableEx (command_str, LE_HIDE, NULL);
i used "LaunchExecutableEx" instead of LaunchExecutable or system, because
with the parameter LE_HIDE i can hide the command window.
> Hey,
> windowsxp ?
(3,707 Views)
