LabWindows/CVI
problem adding library
I'm running Labwindows 6.0, and I'm trying to add the file C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc\nidaqmx.lib to my project. It tells me that the file is not a valid function panel. Any ideas?
-Jason Espinosa
LabWindows 6.0
PCI-6036E
(3,701 Views)
Seems that you have selected an incorrect type of file when loading: if you want to add a function panel you must select a file with .FP extension, or select "library" type file if you want to add a .LIB file.
(3,696 Views)
That's the thing. I'm adding it using the "library options" dialog box, and it says "not a valid function panel".  Beats the heckouttame.
-Jason Espinosa
LabWindows 6.0
PCI-6036E
(3,692 Views)
You can add it using Edit >> Add files to project menu item and selecting .LIB files.
(3,686 Views)
