LabWindows/CVI
problem updating ini file ini file
You're welcome! Smiley Happy
Message 11 of 15
(2,115 Views)
Maybe I am wrong, but in Ini Files, tag names cannot have space in them. Maybe "tag 1" and "tag 2" names cause the io errors.
Message 12 of 15
(1,555 Views)
Yes, I guess that you are wrong Smiley Wink
I am using tags such as "Baud Rate" or "Display Format" without problems.
Message 13 of 15
(1,554 Views)
Yes! Read/Write sequence is essential. You cannot read if you did not write the inserted values first. the other problem with the code is that if it is running real time, your file update may not happen before your read event occurs.
Message 14 of 15
(1,553 Views)
Thanks!
You saved me from testing it... 🙂
Message 15 of 15
(1,549 Views)
