LabWindows/CVI
problems with callback data
I have a few problems with the calbackData attribute. I know that the type of the callback data is a pointer to void. It is my understanding that this is 4 bytes. How do I store an integer value in the callback data instead of a pointer to another stucture. That is, can I store a value in the callback data without declaring a static integer variable and storing a pointer to the variable.
thanks-
Lorrie
(3,586 Views)
Lorrie,
It is an illegal operation to cast a void type as an integer type. You must store a pointer to your integer value into the callbackData, making sure that your integer value is either static/global. As far as I know, the only way to use the callbackData parameter is as follows:
//globally defined
int iData=1;
//this will set the callbackData to point to iData
(int *)callbackData = &iData;
//this will set the locally defined iData2 equal to the
//value pointed to by callbackData
iData2 = *(int *)callbackData;
//iData2 now equals 1
If you find a way to cast a void to an integer, let me know. Good Luck.
Ben
(3,586 Views)
Did you try it like following ?
SetCtrlAttribute (panel, CONTROL_ID, ATTR_CALLBACK_DATA, (void*)12345);
int i;
GetCtrlAttribute (panel, CONTROL_ID, ATTR_CALLBACK_DATA, (void**)&i);
I've often done things like that without problems.
Manfred
lorries323 schrieb in im Newsbeitrag:
50650000000800000087370000-1007855737000@exchange.ni.com...
> t
hanks-
> Lorrie
(3,586 Views)
