LabWindows/CVI
problems with clock() func & triggering
I'm trying to trigger digital outputs on a DIO-16 using a straightforward
loop and using the clock() func to synchronise timings. However the return
values from clock don't seem to behave as I would expect, hence I never get
to set the output bits. Any clues as to why ?
(3,499 Views)
Hi Andy,
The clock() function returns the amount of processor time your program
has used, not the elapsed time. If you want elapsed time, use Timer().
Hope this helps,
Reed.
andy elliott wrote in message <3989e176@newsgroups.ni.com>...
(3,499 Views)
