LabWindows/CVI
programmatically delete items in ring control
Good morning
How to delete all the items in menu ring when i start the program(the list should be empty)
(4,487 Views)
ClearListCtrl() or DeleteListItem()
(4,481 Views)
Normally CVI ring controls are empty at program start, unless you have manually added some elements in the UIR editor that you may want to delete in the IDE. In any case cdk suggestions are the programmatic way of clearing the list any time you want iin your program.
(4,466 Views)
Thanks Roberto and cdk
(4,462 Views)
Veeru wrote:
Good morning
In case you are programming it with LabVIEW you can pass an empty array of string to the property Strings [] of the ring.
(4,454 Views)
