LabWindows/CVI
programmed file transfer between real time target and host
      I am trying to transfer files from the real time target back to the host. And I am trying to avoid loading each file into RT's memory and do the low level tcp/ip or streaming transfer. is there any better way to do it? I notice I can use the FTP client, but in this case, I would need to set up a FTP server and is there any utility functions that I can look into?  Another way I can think of is to use the email attachment, which is a bit of detour.
(3,722 Views)
The following KnowledgeBase article looks like it should be helpful. The related links also look promising for your applications.
FTP Transfer of Files between Host and Real-Time Targets in Measurement & Automation Explorer (MAX)
http://digital.ni.com/public.nsf/allkb/571113C2CE05998E862574E8006005A2?OpenDocument
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(3,668 Views)
Maggie,
Thanks for the reply.
 actually, I am looking for some way I can make the FTP transfer programmably rather than using the MAX FTP tool.
Any ideas?
(3,664 Views)
