LabWindows/CVI
progress bar in CVI 5.5
Hi all,
Can anybody tell me how
to make a progress bar
in labwindows CVI 5.5 ?
MK. Tan
(3,820 Views)
Have you tried with CreateProgressDialog() in the Programmer's Toolbox?
You'll find it in \toolslib\toolbox directory and you can load it as an
instrument or as a library (options/library options).
Roberto
(3,820 Views)
I use a horizontal numeric slide control.
Reed.
Reed Blake
Beta Technology
Industrial and Scientific Computing
MK. Tan wrote in message <39e9bc8e@newsgroups.ni.com>...
>Hi all,
>Thanks,
>MK. Tan
(3,820 Views)
"MK. Tan" wrote:
>>Hi all,>Can anybody tell me how >to make a progress bar >in labwindows
CVI 5.5 ?>>>Thanks,>MK. Tan
To get a Window-like progress bar I tried this way.
#include
#define PB_DELTAPOS PBM_DELTAPOS
#define PB_SETPOS PBM_SETPOS
#define PB_SETRANGE PBM_SETRANGE
#define PB_SETSTEP PBM_SETSTEP
#define PB_STEPIT PBM_STEPIT
extern int CreateProgressBar (int panelhandle, int left, int top, int width,
int height, HWND *handlePB);
extern void DestroyProgressBar (HWND handlePB);
extern void ResetProgressBar (HWND handlePB);
extern int ConvertFromGraphProgressBar (int panelhandle, int controlID, HWND
*handlePB);
#include
#include
//#include NON SI PUO' INCLUDERE PROBLEMI CON GetFileSize
#include
HINSTANCE g_hinst;
static RECT rcClient; // client area of parent window
static int cyVScroll; // height of scroll bar arrow
* CreateProgressBar
* disegna una Progress Bar
* POSIZIONE :
* di default (left = 0, top = 0, width = 0, height = 0) sul fondo della
finestra padre
* altrimenti e' possibile impostare valori diversi per ognuno o qualcuno
dei quattro
* valori impostabili (left, top, width, height)
* RESTITUISCE :
* 1) handle (HWND) della Progress Bar a cui riferirsi per le altre funzioni
* 2) error (int) 0 se operazione riuscita con successo
int CreateProgressBar (int panelhandle, int left, int top, int width, int
HWND hwndParent;
int number, error;
error = GetPanelAttribute (panelhandle, ATTR_SYSTEM_WINDOW_HANDLE,
&number);
hwndParent = (HWND) number;
InitCommonControls();
GetClientRect(hwndParent, &rcClient);
if (height == 0)
cyVScroll = GetSystemMetrics(SM_CYVSCROLL);
else
cyVScroll = height;
*handlePB = CreateWindowEx(0, PROGRESS_CLASS, (LPSTR) NULL,
WS_CHILD | WS_VISIBLE,
(left == 0) ? rcClient.left : left,
(top == 0) ? (rcClient.bottom - cyVScroll) : top,
((left + width) == 0) ? rcClient.right : (left + width),
(height == 0) ? cyVScroll : height,
hwndParent, (HMENU) 0, g_hinst, NULL);
return (error);
int ConvertFromGraphProgressBar (int panelhandle, int controlID, HWND *handlePB)
HWND hwndParent;
int number, error;
int left, top, width, height;
&number);
GetCtrlAttribute (panelhandle, controlID, ATTR_LEFT, &left);
GetCtrlAttribute (panelhandle, controlID, ATTR_TOP, &top);
GetCtrlAttribute (panelhandle, controlID, ATTR_WIDTH, &width);
GetCtrlAttribute (panelhandle, controlID, ATTR_HEIGHT, &height);
cyVScroll = height;
left,
top,
width,
height,
return (error);
DestroyWindow(handlePB);
void SetProgressBar (HWND handlePB)
SendMessage(handlePB, PBM_SETPOS, 0, 0);
#include
#include /* Needed if linking in external compiler; harmless
otherwise */
//#include
#include "panello.h"
static int panelHandle;
// ParseALargeFile - parses a large file and uses a progress bar to
// indicate the progress of the parsing operation.
// Returns TRUE if successful or FALSE otherwise.
// hwndParent - parent window of the progress bar
// lpszFileName - name of the file to parse
// Global variable
// g_hinst - instance handle
#include
#include
#include
int DrawProgressBar (int panelhandle, HWND *handlePB);
BOOL ParseALargeFile(LPSTR lpszFileName);
void EraseProgressBar (HWND handlePB);
HINSTANCE g_hinst;
//int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR
lpszCmdLine, int nCmdShow)
HWND hwndPB; // handle of progress bar
HWND hwndParent;
int number, error;
&number);
WS_CHILD | WS_VISIBLE, rcClient.left,
rcClient.bottom - cyVScroll,
rcClient.right, cyVScroll,
return (0);
HANDLE hFile; // handle of file
DWORD cb; // size of file and count of bytes read
LPCH pch; // address of data read from file
LPCH pchTmp; // temporary pointer
long pippo;
// Ensure that the common control DLL is loaded and create a
// progress bar along the bottom of the client area of the
// parent window. Base the height of the progress bar on
// the height of a scroll bar arrow.
// Open the file for reading, and retrieve the size of the file.
hFile = CreateFile(lpszFileName, GENERIC_READ, FILE_SHARE_READ,
(LPSECURITY_ATTRIBUTES) NULL, OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL, (HANDLE) NULL);
if (hFile == (HANDLE) INVALID_HANDLE_VALUE)
return FALSE;
// cb = GetFileSize(hFile, (LPDWORD) NULL);
GetFileSize(lpszFileName, &pippo);
cb = (DWORD) pippo;
// Set the range and increment of the progress bar.
SendMessage(hwndPB, PBM_SETRANGE, 0, MAKELPARAM(0, cb / 2048));
SendMessage(hwndPB, PBM_SETSTEP, (WPARAM) 1, 0);
// Parse the file.
pch = (LPCH) LocalAlloc(LPTR, sizeof(char) * 2048);
pchTmp = pch;
do {
ReadFile(hFile, pchTmp, sizeof(char) * 2048, &cb,
(LPOVERLAPPED) NULL);
// Include here any code that parses the file.
Delay (0.01);
// Advance the current position of the progress bar
// by the increment.
SendMessage(hwndPB, PBM_STEPIT, 0, 0);
} while (cb);
ResetProgressBar (hwndPB);
CloseHandle((HANDLE) hFile);
return TRUE;
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0) /* Needed if linking in external compiler;
harmless otherwise */
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "panello.uir", PANEL)) < 0)
return -1;
DisplayPanel (panelHandle);
DrawProgressBar (panelHandle, &hwndPB);
RunUserInterface ();
return 0;
int CVICALLBACK ExitApp_xButton (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
EraseProgressBar (hwndPB);
QuitUserInterface (0);
break;
return 0;
int CVICALLBACK StartProgressBar (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
ParseALargeFile ("pippo.ppp");
break;
case EVENT_LEFT_CLICK:
break;
case EVENT_RIGHT_CLICK:
break;
case EVENT_RIGHT_DOUBLE_CLICK:
break;
case EVENT_KEYPRESS:
break;
return 0;
(3,819 Views)
