LabWindows/CVI
prompt to select printer
I'm using the function PrintTextFile to print a file. Instead of just going to the default printer, I would like to have a dialog pop up to select from the printers installed on the machine. How can I do this?
Message 1 of 8
(4,068 Views)
As far as I can see in the documentation, both PrintTextFile and PrintTextBuffer are directed to the default printer in the system. I never tried using this attribute, but you may test to see wether calling SetPrintAttribute (ATTR_PRINTER_NAME, "Printer Name"); before printing permits you to redirect output to a specific printer or not.
Message 2 of 8
(4,049 Views)
The library call to PrintCtrl (print out a control on a panel) calls the Windows printer dialog; the call to PrintTextBuffer does not. How can I call up the printer dialog if printing a text buffer?
Message 3 of 8
(3,710 Views)
I didn't try it, but couldn't you display your text on a hidden or transparent control and then use PrintCtrl?
Message 4 of 8
(3,707 Views)
This is an old post so I don't remember the history of it. I probably found the solution a while ago.
Message 5 of 8
(3,704 Views)
I haven't found it anywhere yet.
Message 6 of 8
(3,700 Views)
You can probably create a hidden control with the text buffer pasted to it and print that out.
Message 7 of 8
(3,693 Views)
see three posts earlier 😉
Message 8 of 8
(3,686 Views)
