LabWindows/CVI
pulse train generation with better precision
I was wondering if there is a way to generate a pulse train with a width that is less than 2 milliseconds using labwindows 7.0 and a PCI-6602, I need more precision.
Derek
(3,725 Views)
What seems to be the problem? According to the catalogue your card has an 80MHz counter so you should in theory be able to do 1/(80 x 10^6) i.e. 12.5 ns.
Maybe I'm missing something! 🐵
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,725 Views)
the problem is, using the GPCTR_Set_Application function and the ND_RETRIG_PULSE_GNR parameter and then using the GPCTR_Change_Parameter function and changing the ND_COUNT_x parameter it only accepts values greater than 1, which would produce a 1ms width. I don't know, I feel I am probably missing something.
(3,725 Views)
Derek,
This is definitely possible. To configure the specifications of the pulse train, you should use code similar to the following:
iStatus = GPCTR_Change_Parameter(iDevice, ulGpctrNum, ND_SOURCE, ND_INTERNAL_100_KHZ);
iStatus = GPCTR_Change_Parameter(iDevice, ulGpctrNum, ND_COUNT_1, ulLOWcount);
iStatus = GPCTR_Change_Parameter(iDevice, ulGpctrNum, ND_COUNT_2, ulHIGHcount);
With the PCI-6602, you can choose one of the following internal timebases:
100 kHz -> ND_INTERNAL_100_KHZ
20 MHz -> ND_INTERNAL_20_MHZ
80 MHz -> ND_INTERNAL_MAX_TIMEBASE
Then, ND_COUNT_1 and ND_COUNT_2 dictate the number of "ticks" of the
timebase that occur when the pulse train is low and high, respectively.
Good luck with your application.
Spencer S.
(3,725 Views)
the problem is that the legal values for ND_COUNT_1 and ND_COUNT_2 are only 2 through 2^32 - 1, so I can not get any smaller widths than 2 "ticks". This means I can only get a width of 2ms using the 100kHz internal timebase.
Derek
(3,725 Views)
Correction: I'm sorry, I meant I could only get a width of 2microseconds, not milliseconds...
(3,725 Views)
> internal timebase.
> Derek
So wy do you not use the other available timebases, e.g.
Stephan
(3,725 Views)
