LabWindows/CVI
pxi-6541 does not show up when I run DAQmxGetSystemInfoAttribute
When I try to detect all of the PXI cards on my PXIe-1065 by running the example program "DAQmx Find Slots" which uses the call "DAQmxGetSystemInfoAttribute" it finds everything except the two PXI-6541 cards that are installed. However the measurement and automation explorer shows them listed under NI-DAQmx devices. What gives?
On a related trail: why can't I use the viFindRsrc call used in the example program called "VISA find resources" to find PXI instruments? It is not in the available Expressions: And I also tried the "?*" option which only finds the "PXIO:1::BACKPLANE"?
Instrument Type      Expression
VXI                  "VXI?*INSTR"
GPIB                 "GPIB[0-9]*::?*INSTR"
GPIB board non-zero  "GPIB[^0]::?*INSTR"
GPIB-VXI             "GPIB-VXI?*INSTR"
GPIB or GPIB-VXI     "GPIB?*INSTR"
VXI or GPIB-VXI      "?*VXI[0-9]*::?*INSTR"
VXI or Serial        "(VXI|ASRL)?*INSTR"
Serial               "ASRL[0-9]*::?*INSTR"
Serial 1,11,111,...  "ASRL1+::INSTR"
Any VXI              "?*VXI[0-9]*::?*INSTR"
All instruments      "?*INSTR"
All resources        "?*"
Remote resources     "visa://hostname/?*"
Memory Access Type   Expression
VXI                  "VXI?*MEMACC"
GPIB-VXI             "GPIB-VXI?*MEMACC"
All memory resources "?*MEMACC"
Bruce
(3,369 Views)
Hello Bruce,
The reason you aren't able to detect your 6541 is because it doesn't use the DAQmx driver.  The 6541 is an HSDIO device and therefore uses a different driver than DAQmx.  The function you are looking for is the niModInst_OpenInstalledDevicesSession which will allow you to choose which session you would like to open.  In this particular case you are looking for niHSDIO.  After this call you can use niModInst_GetInstalledDeviceAttributeViString which will return a list of HSDIO devices.  Take a look at the NI Digital Waveform Generator/Analyzer Help file to see exactly how to use these function calls (specifically the section for NI-ModInst Help>>Fucntion Reference.  Let me know if you have any questions.
(3,349 Views)
