LabWindows/CVI
"Could not load required CVI.NET modules."
I have been using CVI 8.1.1 with no issues on Win7 SP1.  As I'm working from home I installed TestStand 2019.  Now when I run the SimpleTaskMonitor LWCVI sample, I get:
"Could not load required CVI.NET modules. Install .NET Framework version 1.1 SP1 or higher and repair the CVI and CVI Runtime Engine Installers..."
I've repaired the install and shared CVI runtime via the NI manager but have had no success.
Has anyone had this and have a solution?  The last question relating to this was 2010 that I can find, and I've tried the repair suggestions given then.
Many thanks, hopefully,
Steve
(2,376 Views)
Hi Steve,
TestStand 2019 is compatible with LabWindows/CVI however, it only goes back to 2013 SP2.
A full list of the TestStand Compatibility with LabVIEW and LabWindows™/CVI™, I suggest upgrading your LWCVI to enable you to use the two together.
David
(2,153 Views)
