LabWindows/CVI
"Find UI Object" doesn't jump to some controls
I did a search and found other "Find UI Object" posts, but none quite match my observation.
Here is the issue.  I prefer to have my panels spread out in my UIR, without overlap.  This allows me to work on panels without getting lost.
2014-08-19 08_01_02-c__..._SVN Checkouts_ABI - test executive_ABI test sequencer.cws - [Panels.uir _.png
The trouble with this model is that when I choose the "Find UI Object" context menu option from a callback function, it takes me to the top of the UIR, not down below were the panel is located.
If I do the same steps for a control that happens to be located in a panel near the top of the UIR, then all is well.  The UIR is just not scrolling down to show me where the control actually is.
(5,330 Views)
Accepted by topic author ElectroLund
Which version of CVI are you using? Up to CVI 2012 i have observed a similar behaviour but only for controls located on tab panels. I have posted a suggestion in the CVI Idea Exchange on this: you can comment that idea adding your experience and/or kudos it to support it.
(5,317 Views)
Ah, you are correct.  This behavior is actually confined only to controls on tab pages.  My mistake.
(5,315 Views)
It's not a mistake of yours: it's CVI that does not performs well in this case! Smiley Wink
(5,312 Views)
I created a bug report to track this (488375) since this should be considered a bug, rather than a potential feature.
(5,281 Views)
fixed in CVI2020
(2,174 Views)
