Hello Gennady,
I am not sure why your system is rebooting, but I have a few ideas we can try in an attempt to locate the problem. First, does this only happen with a specific project or is this phenomena independent of project? Try debugging some of the projects located in the \samples directory to determine if we can reliably reproduce this behavior with multiple projects. If we cannot, then your project may be doing something unusual, or the project file may have become corrupted. If the behavior is reproducible with other projects, then there may be something wrong with your CVI installation (run Scandisk and/or re-install) or there may be some conflict with other software/hardware within your system. If you run Scandisk and re-install with no chan
ge, then you may try systematically uninstalling/disabling other software/hardware in an attempt to find which one may be interfering with CVI (some try booting to safe mode as a quick check as it disables most drivers). I have recently seen issues with virus scanners and versions of Windows 2000 prior to Service Pack 2 (these have been few and far between, but this gives you some idea of what can go wrong). If you continue to have difficulties, then I would recommend contacting us directly at http://www.ni.com/ask.
Jeremiah Cox
