LabWindows/CVI
"Target Setting" "create console application"
I'm trying to make an application which have 2 modes: commandline if there are some arguments at startup and Graphical only if not.
My problem is that if I dont check  "create console application" in "Target Setting", my application create an extra DOS windows to display my output which is not suitable for scripting, and if I check the "create console application" in"Target Setting" I have always an extra (unuseful) DOS windows in graphical mode.
Is there a way to suppress this DOS windows? and leave the Graphical application live?
Serge
(1,352 Views)
Is this question related to this other one? Even if it's not, you could try the suggestion given there that may be beneficial
(1,328 Views)
Thank you Roberto, You're right, this is exactly the same subject.
But the result is not the one expected,
SetStdioWindowVisibility (FALSE);
do nothing, whatever option I choose (HOST_SYSTEM_STDIO or CVI_STDIO_WINDOW) for SetStdioPort()
The only way I've found is to SetStdioWindowSize (0, 0); to hide the stdio windows.
(1,311 Views)
