LabWindows/CVI
"The User Interface Manager could not be opened."
I installed an application I developed onto a computer with Windows 2000. I've been get the following error: "The User Interface Manager could not be opened." This does not occur on my development computer (also Windows 2000). This error occurs at 2 different locations in my application. When the error occurs it will not show the screen that is supposed to load. Has anyone else experienced this error?
(3,571 Views)
ScottK,
Can you please let us know what software and what versions of that software you are using? Do you get this error in CVI or in TestStand?
Shannon R
(3,571 Views)
I'm using Labwindows CVI 6.0 with Windows 2000. I have a little more information now about when the error happens after the application is installed. The error only happens if I run the program using the shortcut under Start > Programs > My Application. But if I open the folder where the executable is located and I run it from there I do not get the error. Strange.. Thanks for the help.
(3,571 Views)
