LabWindows/CVI
"Unrecoverable Internal Error at 001B:10067EB5 LabWindows/CVI will aborted
"Unrecoverable Internal Error at 001B:10067EB5 LabWindows/CVI will aborted" error is coming several times in a day while building the project. This is very critical problem for me now because I am now in our clients place to instal our software which was developed in LabWindows/CVI and I have started our accpetence procedures with them. We were using LabWindows in other systems for complete developement and we didnt faced this problem till now. This system is a new IBM system with Windows 2000 OS. I am getting this error while building the application. I tried by removing the software and reinstalling it. But still this error is coming. If I delete the "cvibuild.AtlasUI" folder and also the executables and rebuild again, the problem wont come. But after some time, again the error will come. I need an urgent solution for this. Otherwise it will be a great problem for me.
(3,565 Views)
I would like to ask you for more information regarding this particular issue. Do you have any sort of steps to accurately reproduce the Internal Error? Does this error happen when the project is built in either Debug or Release mode, or does it only happen in one particular mode?
Scott Y.
NI
(3,538 Views)
Scott Y.
I am getting this error in both debug and release modes.
And I can not reproduce this error the very next time.
But I am sure that within 3 or 4 trials of building the application, the error will happen.
Joesam
(3,533 Views)
Joesam,
Could you tell us what you're doing in your code? Are you using any external code in your project, such as instrument drivers (.fp) or DLLs? Does the error occur every time you build the project without deleting the "cvibuild.AtlasUI" folder? A more detailed description of how the error is coming about would help!
E. Sulzer
E. Sulzer
(3,511 Views)
