LabWindows/CVI
"cell comment"
Hello everyone!
I have problem with reading comments of cells in Excel.
I can add,clear comments of cells but I don't know how
could to read this comment in LabWindows ,in VBA I know it. Can anybody help me?
(3,060 Views)
Hello BranoG,
You can read cell comments in Excel by using the Excel Report instrument. The Excel Report functions are located in ..\CVI71\toolslib\activex\excel\excelreport.fp.
In particular, the function you should look at is ExcelRpt_GetCellRangeAttribute() with the attribute set to Comment (ER_CR_ATTR_COMMENT).
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,034 Views)
Thank you WENDY:) it,s running.
And for other users...you can find ExcelRpt_GetCellRangeAttribute() also in CVI60\samples\activex\excel\excelreport.fp
if you want make your own fnc then use this:
Excel_GetProperty (ExcelSingleCellRangeHandle, NULL, Excel_RangeComment, CAVT_OBJHANDLE, &ExcelCommentHandle);
Excel_CommentText (ExcelCommentHandle,NULL,CA_DEFAULT_VAL, CA_DEFAULT_VAL,CA_DEFAULT_VAL,&charCommentText );
(3,015 Views)
