LabWindows/CVI
"error setting test mode" displays when loading software in test executive
programs which run ok when using labwindows/cvi don't when loaded in test executive (old versions of test executive and labwindows).
(3,006 Views)
Hi!
I hope you are doing well today! You will need to be more descriptive. What versions of LabWindows/CVI and Test Executive are you using? Is there an error number you get when you run the program? Was the program working before? What changed?
Also, what is the motivation of sticking with these old versions? Have you considered moving over to TestStand?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,965 Views)
