LabWindows/CVI
"outportb" function is available in CVI ? where can i fine it ?
(2,987 Views)
Hi Walter,
In CVI (ANSI C) programming, the equivalent of outportb is outp. Outp can be found under the Utility Library >> Port IO. Open the function panel and right click anywhere on it to pull up the context help, which will give you the parameter information and how to call this function.
Jeremy L.
Jeremy L.
(2,987 Views)
