LabWindows/CVI
read Unicode strings from file (LabWindows/CVI does not have wchar.h ??)
I put a Unicode string into a text file (Chinese in this case).
I read from Internet that you need to #include to use the functions for Unicode strings.
However when I try to do that in LabWindows/CVI, the compiler does not understand what is wchar?
Do you have any solution for my problem/ or any other solution for my problem (reading Unicode string (Chinese) from file and then print it out correctly??
I realy appreciate and thank to anyone who answers.
(4,668 Views)
I wrote "wchar.h" after the #include in the above post but for certain reasons it is not shown in the first post.
This post is just to tell you that.
(4,666 Views)
I never used unicode characters in my applications but looking in the Knowledge Base I found this entry that can be useful for you together with the other entries mentioned in that page.
(4,643 Views)
I am using LabWindows 7.0.
After reading those entries, I see that they say we can not have Chinese or Japanese characters in LabWindows/CVI. The program does not support. However, the entries are for LabWindows 6.0. Maybe we still have that problem in 7.0?
They say we need a Chinese or Japanese OS to be able to display multi byte characters.
Any solutions ??
(4,636 Views)
