LabWindows/CVI
reading from file into array of structures
I would like to read from file into  array of structures. The file can be organized as one structure per line:
3000,3200,3,17,1,1,3
3201,3400,3,18,5,2,1
My intent is to initialize some integer constants depending on a frequency band given by first two elements in structure as follows:
I'm not sure how to initialize the structure from the file.
typedef struct {
    double lowFreq;
    double highFreq;
    int doubler;
    int PreN;
    int mult;
    int N;
    int cpGain;
} Band[numBands];
    for (i = 0; i = numBands; i++) {
        if ((inFreq >= band[i].lowFreq) & (inFreq <= band[i].highFreq))
                doubler = band.doubler;
                PreN = band.PreN;
                mult = band.mult;
                N = band.N;
                cpGain = band.cpGain;
(2,693 Views)
Accepted by topic author the_emc_guy
Given the file structure you have reported, I see no way of reading it other that using either standard C functions (fopen, fgets, fclose) or their equivalents in the CVI Formatting and I/O Library (OpenFile, ReadLine, CloseFile). The help file for the functions include links to some example programs that may help you to design your own code.
(2,677 Views)
That's what I'll do.
Thanks.
(2,656 Views)
