LabWindows/CVI
real time intensity graphs
Can somone tell me if it is possible to make intensity plots real time.
I am currently
filling a 256 by 256 array one row at a time with data from a counter. I
would like to
plot each row as it comes out without replotting any old rows nor any new
rows of the
array currently empty of data. Using the command PlotIntensity forces me
to replot
the entire 256 by 256 array each time which tremendously slows down the program.
If anyone can help this would be much appreciated
thanks
ken
(3,837 Views)
Hi Ken,
I'm very sorry I cannot help you with your problem. However I do know someone
who may be able to help. I'm too struggling with the plotintensity function.
I'm finding it difficult to define the ColourMapArray. Can you help please!!
(3,837 Views)
Hello Ken,
I have the same question. If you've had any response on your question, please
forward the
answer to me: bjorn_schellens@yahoo.com
thanks in advance.
(3,837 Views)
I solved this problem rather nicely by using a canvas and the CanvasScroll
function. You can draw line or blocks of color (after having scaled them
properly, but that is easy) on the right side and then scroll to the left by
the same amount of pixel.
Guillaume Dargaud
CNR/IFA
http://sung3.ifsi.rm.cnr.it/~dargaud/Hack/LabWindows.html
http://sung3.ifsi.rm.cnr.it/~domec/
http://sung3.ifsi.rm.cnr.it/~chooyu/
1. When computing, whatever happens, behave as though you meant it to
happen.
2. When you get to the point where you really understand your computer, it's
probably obsolete.
3. The first place to look for information is in the section of the manual
where you least expect to find
it.
4. When the going gets tough, upgrade.
5. For every action, there is an equal and opposite malfunction.
6. To err is human... to blame your computer for your mistakes is even more
human, it is downright natural.
7. He who laughs last probably made a back-up.
8. If at first you do not succeed, blame your computer.
9. A complex system that does not work is invariably found to have evolved
from a simpler system that worked just fine.
10. The number one cause of computer problems is computer solutions.
11. A computer program will always do what you tell it to do, but rarely
what you want to do.
- Murphy's Laws of Computing.
(3,837 Views)
