LabWindows/CVI
regarding Radio buttons
   how do i group radiobuttons, so as to provide mutual exclusion property....
thanku
(3,766 Views)
Hellow,
you can add a radio group (Custom controls->Toolslib controls) instead of seperate radio buttons.
Hop this helps.
(3,759 Views)
One other way you could do this:
  • Set the default state to all radio buttons to OFF, except for one of them
  • Have all radio buttons trigger the same callback function
  • Within this callback function, have the EVENT_COMMIT section of code set ALL radio buttons to OFF
  • Using the control parameter passed to the callback, identify which radio button was actually clicked
  • Use SetCtrlVal() to re-set the desired radio button back to ON
This can be made more elegant by using an array to store the control identifiers:
  • int radio [] = {PANEL_RADIO1, PANEL_RADIO2, PANEL_RADIO3};
and then do the above processing within a simple loop.
JR
(3,753 Views)
thanku.....
Kimaya
(3,735 Views)
