LabWindows/CVI
removing plot legend from a graph?
Hi - another question from a beginner:
Following the tutorial, I created a graph. The graph has a small box to its right where a legend for the various plots go. (I'd post a pic, but it looks like I'm not yet permitted to do that.)
The purpose of the graph is to plot several thousand points on a cartesian plane. I got this working (sort of) with the function PlotPoint(). When I run the program, though, the sheer number of points quickly overwhelms the capacity of this legend (and stalled the program to boot).
So: can I get rid of this legend somehow? On a side note, am I being inefficient with this approach? Would it be better to gather the points in to an array and use PlotXY instead?
Thank you.
(4,073 Views)
Accepted by topic author mzimmers
concerning the legend, open the respective popup panel by pressing the Legend button on the Edit Graph control panel:
 On top of this panel you will see a check box Show Legend:
This check box should do the job...Smiley Wink
Concerning the choice of plotting functions: I wouldn't plot 1000 individual data points, but rather use PlotXY. Alternatively you can consider using a strip chart instead of  a graph, which allows you to add one data point after the other
(4,068 Views)
Oh man, how did I miss that one...thanks, Wolfgang.
(4,051 Views)
