LabWindows/CVI
retrieving values from XML child elements
I have the following simple XML code and I am trying to retrieve the values from the child elements C1 and C2 and put it in a buffer to use later on. However I always get an error... Can someboby point out what I am missing?
Thanks.
(My xml code)
<?xml version="1.0" encoding="ISO-8859-1"?>
<Test>
 <C1>1000</C1>
 <C2>2000</C2>
</Test>
(My LabWin code)
void getChannelValues()
 char ch1[25], ch2 [25] = NULL;
 CVIXMLStatus status;
 CVIXMLElement C1 = 0, C2 = 0;
 CVIXMLDocument test1;
 status = CVIXMLLoadDocument ("C:\\Temp\\test.xml", &test1);
 status = CVIXMLGetElementValue (C1, ch1);
 CVIXMLDiscardElement (C1);
 CVIXMLDiscardDocument (test1);
 CVIXMLGetElementValue (C2, ch2);
 CVIXMLDiscardElement (C2);
(4,391 Views)
Try this code:
#include <cvirte.h>
#include "CviXml.h"
char ch1[25]="", ch2 [25]="";
CVIXMLElement RootElement;
CVIXMLElement C;
int main (int argc, char *argv[])
    if (InitCVIRTE (0, argv, 0) == 0)
        return -1;    /* out of memory */
 status = CVIXMLLoadDocument ("test.xml", &test1);
 status = CVIXMLGetRootElement (test1, &RootElement);//<Test>
 //Get C1 tag value
 status = CVIXMLGetChildElementByTag (RootElement, "C1", &C); //"<C1>"
 //status = CVIXMLGetElementValueLength (C, &len);
 status = CVIXMLGetElementValue (C, ch1);
 CVIXMLDiscardElement (C);
 //Get C2 tag value
 status = CVIXMLGetChildElementByTag (RootElement, "C2", &C);//<C2>
 status = CVIXMLGetElementValue (C, ch2);
 CVIXMLDiscardElement (RootElement);
    return 0;
(4,377 Views)
Howdy qsa301,
I would also like to add to refer to our LabWindows/CVI XML shipping examples (Help >> Find Examples; type "XML" in the Index tab) that demonstrate using several XML functions. These examples should also give you some more insight.
Hope this helps!
Jonathan N.
(4,364 Views)
Thank you all for your help
(4,344 Views)
