LabWindows/CVI
return value of strtod() if string equals to zero
as per article:
zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvistrtod/
If no conversion is possible, the function returns zero.
what if my string equals to zero (i.e., 0.0000)?  how can I know if there is no error from the conversion?
(5,587 Views)
You may check errno. If it is set to EINVAL , you know rthat there was an error.  But unfortunarely the standard (http://pubs.opengroup.org/onlinepubs/009695399/functions/strtod.html)  doesn't require setting errno to EINVAL for that case.
(5,573 Views)
using this code as an example:
char    *Y = "XYZ";
double  MyNum;
char    *MyEndPtr;
int     Err_Conversion = 0;
errno = 0;  //reset
MyNum = strtod (Y, &MyEndPtr);
if ( (MyNum == 0) && (strcmp(Y, MyEndPtr) == 0) && (*MyEndPtr != '\0'))
        { Err_Conversion = 1;   }
when an error occurs:
  1. MyNum = 0
  2. the address where the error occurs (beginning or middle of string) is stored in MyEndPtr.
  3. the content of MyEndPtr is not null.
(5,530 Views)
OK, scratch my reply above.  this is the more correct one:
char    *Y = "XYZ";
double  MyNum;
char    *MyEndPtr;
errno = 0;  //reset
if ( (MyNum == 0) && (strcmp(Element [LineCount][i],MyEndPtr) == 0) && (*MyEndPtr != '\0') && (errno != 0))
  1. MyNum = 0
  4. errno != 0 if underflow or overflow occurs, in which case MyNum is set to +/–HUGE_VAL, with HUGE_VAL sign matching the sign of the value that cannot be represented.
(5,523 Views)
I just want to highlight that a test for equality on a double value is very prone to errors: I suggest to use FP_Compare () function instead. See the function help for a detailed explanation of the problems such a test can encounter and how the function manages to avoid them.
(5,503 Views)
