LabWindows/CVI
rs232 16bit
ok , for some reason today when we were scoping to see what we were sending out, all of my bits were reverse.
so say for instance if i set outputdata[4]=1;
on the scope machine it would send out 1000000 instead of 00000001.
so that could be an issue. also on the scope machine we kept seeing extra bits ,  it would throw in a 1 0, so everytime the 1 0, i would se my next element of the array.
so i dont know whats thats all about.
then also my element [6] wasnt the correct sum, so im going to try one more thing and then say its a hardware issue. but you can assist me if you want.
#include <ansi_c.h>
#include <visa.h>
#include <userint.h>
#include <rs232.h>
#include <utility.h>
#include <stdio.h>
#include "visa.h"
#define MSCARD_BYTE        0x00
#define NUM_ADDRESS_BITS   0x5
#define    NUM_BYTE_IN_CMD    0x7
#define NUM_BYTE_IN_RESP   0x7
#define SEND_CHKSUM_BYTE   0x6
#define RECORD_CHKSUM_BYTE 0x2
#define REC_BUSERROR_BYTE  0x3
#define TEXT_LENGTH        2000
#define COMPORT            10
#define BAUDRATE           115200
#define DATABITS           8
#define PARITY             0
#define STOPBITS           1
#define INPUTQ             512
#define OUTPUTQ            512
#define STRINGSIZE         7
int MASTER_RESET_UPDATE_DEVICE ( int CommandCode,int deviceAddress, int data );
//static char COM[6] = "COM10\0";
unsigned char   outputdata[NUM_BYTE_IN_CMD];
unsigned char    inbuff    [NUM_BYTE_IN_RESP];
int bytes_sent=0;
int bytes_read=0;
char read_data[TEXT_LENGTH];
int main()
    //    MASTER_RESET_UPDATE_DEVICE('R',0,0);
        MASTER_RESET_UPDATE_DEVICE('U',0x1,0xFA);
        return 0;
int MASTER_RESET_UPDATE_DEVICE (int CommandCode, int deviceAddress, int data )
    int device_err;
    int msblsb=0;
    int MSCardAddress=0;
      //  CommandCode='U';
      // deviceAddress=0x1;
      //  data=0xFA;
    device_err= OpenComConfig(COMPORT,"",BAUDRATE,PARITY,DATABITS,STOPBITS,INPUTQ,OUTPUTQ);
    memset( outputdata, 0, NUM_BYTE_IN_CMD);
    memset( inbuff,     0, NUM_BYTE_IN_RESP);
  outputdata[MSCARD_BYTE] = MSCardAddress;
    outputdata[1] = CommandCode; //'U';
    // embed controller number and device address into output message
    /*data <<= NUM_ADDRESS_BITS; // left shift data bits
    msblsb = data | deviceAddress;  // combine data and address bits
    outputdata[2] = (msblsb>>8) & 0xff;  // Set MSB
    outputdata[3] =  msblsb & 0xff;  // Set LSB
    outputdata[4];
    outputdata[5];
    // calc check sum
outputdata[6] = outputdata[0] + outputdata[1] + outputdata[2] + outputdata[3] +outputdata[4]+ outputdata[5];
    outputdata[6] = outputdata[6] & 0xFA;
    bytes_sent=ComWrt(COMPORT,outputdata,NUM_BYTE_IN_CMD);
    Delay(0.5);
    bytes_read=ComRd(COMPORT,inbuff,NUM_BYTE_IN_CMD);
        if (bytes_read != NUM_BYTE_IN_CMD)
        MessagePopup("%s","NOT READING ANYTHING, CHECK HARDWAREV!!");
        // Get response from COM device
        if (bytes_sent != NUM_BYTE_IN_CMD)
        MessagePopup("%s","CAN'T WRITE TO DEVICE, CHECK COMPORT SETTINGS!!");
    // compare card Address bytes
    if (outputdata[MSCARD_BYTE] != inbuff[MSCARD_BYTE])
                MessagePopup("%s","CHECK CARD ADDRESS!!");
       // compare checksum bytes
    if (outputdata[SEND_CHKSUM_BYTE] != inbuff[RECORD_CHKSUM_BYTE])
        MessagePopup("%s","CHECK SUM BYTE NOT EQUAL!!");
    // Check returned status byte
    if (inbuff[REC_BUSERROR_BYTE] == 0)
        return VI_SUCCESS;
return 0;
Message 11 of 12
(1,242 Views)
Message 12 of 12
(1,236 Views)
