LabWindows/CVI
run a setup.exe
Hello fellows,
I'm trying to run a setup program from Labview using the system cmd from the front panel.
I send this cmd : cmd "C:\Program Files\National Instruments\LabVIEW 8.0\data\Driver USB-GPIB\setup.exe"
Nothings happen, unless the promt cmd appears and disappear immediatly.
Any help ?? thanks
(3,675 Views)
You will probably get more answers if you posted this question on the LabView board; this is the LabWindows one. Smiley Happy
JR
(3,668 Views)
LabVIEW help explains that for Windows, you have to write your command like this (here, to launch the notepad):
cmd /c %SystemRoot%\system32\notepad.exe
In what you write, the '/c' is missing.
Cordially,
Message Edité par Mathieu R. le 08-02-2007 09:52 AM
(3,639 Views)
