LabWindows/CVI
run time error
I start running my programm and i receive this message " FATAL RUN-TIME ERROR: Unknown source position, thread id 0x0000244C: A non-debuggable thread caused a 'General Protection' fault at address 7765E6DF." i don't know how to resolve it.
My program was working well and now i have this probem.
Please i need you help.
Thanks.
(3,927 Views)
With such a generic issue, here are 2 generic suggestions:
1. Use the resource tracker to make sure you have no memory leaks. Are you using any add-on libraries/tookits? At one time the imaging module could allocate memory, and the resource tracker did not warn when you failed to free it. I do not know if this has been fixed.
2. Turn on the compiler warnings. Which version of CVI are you using? Versions after 2013 (inclusive) use the Clang compiler, which has a large number of warnings you can turn on, but many are off by default. I normally run with all warnings enabled apart from the exceptions below. I suggest you turn on all warnings except the ones below, and make sure that you fix all warnings except those you fully understand.
(3,920 Views)
Thanks for your answer,
I have CVI 8.5 , the problem is that after reinstalling it i have this problem even i create a new project i have this error.
I don't know the origine of it 😞
(3,910 Views)
