LabWindows/CVI
running TestStand enrty point in interactive execution
I'm trying to write my own user interface and run an interactive execution of TestStand. I want to to run the SinglePass and TestUUT entry points but all i've succeded to do is to run the MainSequence entry point. when trying to load the model before runing the sequence the execution just skips the test sequence.
what an I doing wrong?
(2,861 Views)
Hagay,
When you specify the propcess model, the sequence name should reflect sequences available in the process model. Example "Single Pass" or "Test UUTs". If you use "MainSequence" it should just skip everything since the MainSequence in the process model is empty.
In Addition, this sounds more like a TestStand question rather than CVI, maybe next time you should post similar messages in the TestStand group.
Roberto P.
National Instruments.
(2,861 Views)
