LabWindows/CVI
save change for the next run
I have a question about saving change for the next run.
Here is an example,
When I run the code, the program will import reference data from a predefined default folder A. I can change the reference by selecting a different folder B but once I quit and rerun the code,  I  need to select folder B again.
My question is: how can I record this change so that the program can directly read data from folder B for the next run?
wmf
(3,048 Views)
Two common ways to do this are to use inifile.fp to save the information between sessions in an .ini file.  See this link for more:
http://forums.ni.com/ni/board/message?board.id=180&message.id=11113&query.id=14896#M11113
Or there are functions in the toolbox to save information in the registry.
http://forums.ni.com/ni/board/message?board.id=180&message.id=882&query.id=14916#M882
Message Edited by mvr on 07-28-2006 02:19 PM
(3,045 Views)
