LabWindows/CVI
saving jpeg from the web
I am trying to save images from web pages to a local drive
i have tried using the inet.fp and can successfully load the jpeg from a url to a panel containing an activex webcontroller item. The jpeg is displayed correctly using :
GetObjHandleFromActiveXCtrl (phMap2, pMap2_WEBBROWSER,&webHandle);
Fmt (strUrl, "%s<%s/%i/%i/%i%s","http://tile.openstreetmap.org",zl, x, y, ".png");
inet = INET_IWebBrowser2Navigate (webHandle, NULL, strUrl, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
CA_DEFAULT_VAL, CA_DEFAULT_VAL);
using the following command i can save the file but am always prompted with the file save as pop up
INET_IWebBrowser2ExecWB (webHandle, NULL, INETConst_OLECMDID_SAVEAS,
INETConst_OLECMDEXECOPT_DODEFAULT, CA_VariantNULL(),
&vOut);
is it possible to fix the file path and filename so this process can be automated ? or is there a better way of doing this ?
Message 1 of 1
(4,027 Views)
