LabWindows/CVI
scroll bar custom control
I am using the scroll bar custom control and was wondering if there is a way to set the thumb color to be different than the scroll bar color. If you use the ScrollBar_SetAttribute() function to change the color it always changes both the scroll bar color and the thumb color making it almost impossible to see the thumb.
Jim Vander Werp
Smiths Aerospace
Grand Rapids, MI
(3,542 Views)
There's no way to do it through the API provided with the scroll bar custom control. However, the source code for the custom control is provided in \toolslib\custctrl\scroll.c, and you can make that change yourself.
You just need to change the function DrawScrollBarThumb in scroll.c. Change the fillColor parameter of the call to PlotRectangle where the thumb is drawn, and that should do the trick.
- jared
(3,528 Views)
Jared,
Super, that's exactly what I needed, I have it looking much better now!
Jim
(3,520 Views)
