LabWindows/CVI
semaphore vs notifier
Hello All,
Please excuse my ignorance, I am a hardware guy and very new to Labview.  I conceptually cannot understand the difference (after going through the tutorial) between the two aforementioned subjects.  It appears to me that a notifier holds a task from performing until it sends notification to that task and the task rcvs it, but isn't this the same thing a semaphore is doing??  In essence the notifier is locking out the task from performing until it receives the notification.
P.S. I am not even sure if I am in the correct discussion forum for this.
thanks for the response
Washburn
(3,247 Views)
Correct! You're in the wrong forum! This is for LabWindows/CVI topics- you will be better off in the LabView forum.
JR
(3,242 Views)
