LabWindows/CVI
send Windows Message
I want to send a user defined windows message between 2 CVI process. So, I have to get the HNWD using FindWindow() but the class name seems to change between 2 process.
Thank's for any pointer.
(3,363 Views)
Hello
Check out the CVI example that uses the Programmers toolbox to send custom messages across panels, you can find it under ../cvi/samples/toolbox/msgdemo.prj.
Also, you can set the classname for FindWindow() to NULL, and you can still should be able to get a handle to the window.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,363 Views)
