LabWindows/CVI
sending email through gmail-Error -1172
Hi, i am new . trying to figure out this VI codes. When i key in my gmail accout and run the program, i face the Error -1172 . I am not sure if i need to edit some SMTP server setting or the port setting. can any1 explain why i keep having this error?
thk in adv
(4,306 Views)
this is the forum for CVI, not LabVIEW. You will get much better support in the appropriate forum. Good luck!
(4,303 Views)
I hope this error due to the Proxy setting. you may need to set the proxy settings to communicate the smtp.
(4,020 Views)
I also facing the same situation when I tried to sending email through Gmail error 1172 it shows an error iTunes sync error 54, so I really want a proper solution how to remove this error then please share with me.
(2,615 Views)
