LabWindows/CVI
serial printer works in debugmode does not work in released
I am working with serial printer and I can print label in debug mode but in rrelease mode my printer does not print label.
Here is what I am using...
 size = strlen(read_file);  //read_file is a char array.
 written = ComWrt (PRINTER_PORT, read_file, size);    //print prints 2 lables if size-3 is used
Printer is intermec easycoder PM4i.
Any help?
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(4,000 Views)
Forgot to mention that read_file array size is appr. 6000+ characters.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,994 Views)
The obvious place to start is to see if read_file is null terminated.  If you print out the value of size in debug and release mode, does it change?  If it does, then the initialization of the read_file array to zero by debug mode is providing the null termination of read_file required for strlen() to work correctly.
(3,973 Views)
Hi Sheetal,
Well In debug mode things work at a slower rate than release mode. So considering you are writing to the serial port....there could be time outs occuring or if u are using wait loops or anyting.....in release mode these are executed at a faster rate.
My suggestion from over the top is you should get a port monitor software, capture the port u using, have a breakpoint write after that line.....and observe what was sent out....
Hope it helps....if u can provide more parts to ur code that could help narrow the problem.
k1_ke
(3,958 Views)
Thanks for your response.
It is very strange. It some time works in release mode and some time does not. Even if I don't change any thing in my code. I am still investigating this problem and post solution if I find one!
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,926 Views)
Ok. Here is what I found. It still does not work in release mode
Here is my code.
 FlushInQ (PRINTER_PORT);
 FlushOutQ (PRINTER_PORT);
 size = strlen(read_file);  //size is > 6000 bytes
 if(written != size)
  Error(__FILE__, __FUNCTION__, __LINE__, "Printer Bytes written is not same as filesize FAILED");
  Write_Status("Printing Error FAILED");
  Write_Message("Printing Error FAILED");
  return FAIL;
return PASS;
I used serial port monitor and in release mode I do not see any data but in debug mode I do see data. So problem is on PC side not on printer side.
In release mode I do not get error. that means bytes written is same as size.
It this functions always returns PASS.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,908 Views)
I think I found problem.
here is my code where I read a file.
 stream = fopen (PRINT_FILE_MASTER, "r");
 written = fread (read_file, 1, size, stream);
 fclose(stream);
if PRINT_FILE is    "print.txt"   it does not work in release mode. my project location is Z:\ .
But If I use "Z:\print.txt"   it works.. in release mode.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,902 Views)
