LabWindows/CVI
set chart color in excel
i hope someone can help me.
i had to set the colors of chart in excel from LV.
does someone know how to do this?
markus
(3,030 Views)
Markus,
you propably should ask Microsoft on that one.
Nevertheless, there is an easy way to solve this: I think that you already use ActiveX to communicate with Excel. If you want to change properties of Excelsheets via ActiveX, the best solution is:
Create a makro (using the recording functionality of Excel) which does exactly the desired and then port the makro to LabVIEW......
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,992 Views)
