LabWindows/CVI
set table column width automatically
when putting a string in a table cell using the SetTableCellVal function (or SetTableAttribute with ATTR_CTRL_VAL), is there any way to adjust the column width automatically, so the entire string can be seen by the user? It seems that the column attributes Fit Mode and Size Mode can only be used for picture cells, not for strings Smiley Sad . If this is not possible, how can I check the width (in pixels) of the string that I am putting in the table cell?
All hints are appreciated,
Wim
(4,563 Views)
I am also interested in such a feature that I have not found till now.
At present the only solution seems the use of metafonts: if I am using a metafont I can obtain the lenght of the string via GetTextDisplaySize command, so that I can adequate column width according to the size obtained.
(4,558 Views)
Wim, Roberto,
Actually, there is a function that lets you do this. It's called SetColumnWidthToWidestCellContents. It works for both trees and tables.
Luis
(4,549 Views)
Thanks a lot.
Roberto's solution was working fine, but it is of course more elegant to do it in jut one line of code, and I can reduce my list of local variables.
(4,522 Views)
LuisG wrote: Wim, Roberto, Actually, there is a function that lets you do this. It's called SetColumnWidthToWidestCellContents. It works for both trees and tables. Luis
Mmmm, introduced in version 7: seems I need to re-study what's new in that version! Smiley Surprised
Thanks you very much, Luis.
(4,517 Views)
