LabWindows/CVI
setting panel attribute ATTR_CLOSE_ITEM_VISIBLE causes panel to blink
Hi
Can someone find a reason why setting ATTR_CLOSE_ITEM_VISIBLE panel attribute to 0/1 causes the panel to blink?...Attached a small program.
I use CVI 2012 SP1. Windows 7 64.
I could only find this on the web: http://natinst.public.labwindows-cvi.general.narkive.com/Dp6nIHb2/setting-close-control-causes-scree...
(4,457 Views)
Hi Ramy,
Changing the ATTR_CLOSE_ITEM_VISIBLE attribute causes the ATTR_SYSTEM_WINDOW_HANDLE to be invalid and the window is recreated everytime.
When the delay function is used, it prevents the window to be recreated; hence the blink. If you simply set the attribute to "0" without the delay and don't set it back to "1" again, the red X that closes the window will be disable without the window blinking.
Can you let me know why you want to set the attribute to 0, then 1 again?
Ren H.
Applications Engineering
(4,392 Views)
Hi ren,
Thanks for your answer.
The delay in my program was just for the example...
I encounter the problem anytime I set this attribute, even once.
Here is a second example - set the attr only once, without a delay. I'll appretiate your help.
Ramy
(4,380 Views)
Hi Ramy,
Thanks for the code! I run it on my side and it seems to work fine. The X button of the panel window is dimmed when the switch is ON.
I am running LabWindows/CVI 2015. Can you download the 2015 version and see if the same behaviour presists?
Ren H.
(4,366 Views)
Hi Ren
1) When you say "it seems to work fine" do you mean it is not blinking?
When I turn the switch on/off the panel is blinking.
2) I don't have a license for CVI 2015.
Ramy
(4,356 Views)
Hi Ramy,
Yes, when I ran you code, the panel did not blink when I toggled the switch.
NI software come with a 7 day evaluation period. This behaviour might be isolated to the 2012 version.To find out, just install CVI 2015 for troubleshooting.
Ren H.
(4,340 Views)
Hi Ren
I've just tried my example in CVI 2013, and the panel blinks.
Anyway, CVI 2015 is not a solution for me right now. Thanks.
(4,327 Views)
