LabWindows/CVI
shifting an unsigned int by 32bits to the left gives bad result
When I try to shift a 32bit unsigned integer value to the left by 32 bits, I should have a result value of 0. But instead of that, I get back the original content of the shifted variable.
Example code:
unsigned int uiVal = 0x01;
unsigned int uiResult;
    uiResult = uiVal << 32;      //uiResult should have the value of 0, but I get a value of 1.
How it can be?
(3,170 Views)
I think you will find that a shift operation must be less than the number of bits in the word being shifted, or else the result is undefined. So for a 32 bit integer, you cannot shift by more than 31. Can't lay my hands on the C documentation right now - relying on my memory. (A risky strategy...)
JR
(3,167 Views)
Hmm.. I'm going to have to start reading these messages from newest to oldest, instead of the other way round. That's twice today I've been caught out replying to duplicated posts which already have perfectly good replies to the later version.
JR
(3,160 Views)
