LabWindows/CVI
show multistrips in one chart
Can i show multistrips in stack plot mode just like in labview(in labview i can set overlay plot mode and stack plot mode)
thank u!
(2,810 Views)
Hello
are you asking whether in CVI you can change one graph control into multiple graphs, while having to reference only one control? If that is what you are asking, then the answer is no. You will need to have multiple plots in CVI in order to do so. You can create multiple plots programatically in CVI to achieve the same effect though.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,810 Views)
