LabWindows/CVI
showing grid lines as dashed lines
Dear All,
i am using a waveform chart to plot my data .. i want to insert grid inside my chart .
There are 3 different options for inserting grids in d chart .
is dere any way i can change the style of lines of grids ?? i want to see them as dashed lines rather than a continous line ...
Ritesh
(2,768 Views)
Ritesh,
I don't believe there is any way to change the style of the grid lines on the graphs in CVI.  The only options exposed to us are the visibility & color.  You might be able to try to do something fancy with making your own grid lines by plotting data on the graph, but it might be difficult to get it setup correctly.
John B.
(2,748 Views)
