LabWindows/CVI
shut down of windows NT through an application running with LabWindows/Cvi
Can you explain me which instructions I have to use for shut down windows Nt from an LabWindows application.
(3,288 Views)
According to Windows SDK you should use
ExitWindowsEx(EWX_FORCE, 0);
Look at the reference for this function for a detailed description of the first parameter (for example you could simply log your user off...).
You must #include in your project.
I used it in Win95 and Win98 and it works well. I hadn't tested it in NT, but it's simple to try...
Hope this helps.
Roberto
(3,288 Views)
Windows NT is a bit different to Win 98
This code should do the trick for you.
#include "stdafx.h"
#include "WinUtil.h"
#include "WinUtilDlg.h"
#include "WINUSER.H"
void shutdow()
HANDLE hToken;
TOKEN_PRIVILEGES tkp;
// get the token for this process
if(!OpenProcessToken(GetCurrentProcess(),
TOKEN_ADJUST_PRIVILEGES | TOKEN_QUERY, &hToken));
// get the LUID for the shutdown privilegde
LookupPrivilegeValue(NULL, SE_SHUTDOWN_NAME, &tkp.Privileges[0].Luid);
tkp.PrivilegeCount = 1;
tkp.Privileges[0].Attributes = SE_PRIVILEGE_ENABLED;
//get the shutdown priviledge
AdjustTokenPrivileges(hToken, FALSE, &tkp,0,(PTOKEN_PRIVILEGES)NULL, 0);
ExitWindowsEx (EWX_SHUTDOWN | EWX_FORCE,0);
"Roberto Bozzolo" wrote in message
news:50650
00000050000005A1F0000-984882144000@quiq.com...
> off...).
> Hope this helps.
> Roberto
(3,288 Views)
>This is a correction to the first posting.
> #include "stdafx.h"
> void shutdow()
> HANDLE hToken;
ge
> news:5065000000050000005A1F0000-984882144000@quiq.com...
> > off...).
> > Hope this helps.
> > Roberto
(3,288 Views)
Hi Mark,
Do you have a DLL or EXE version of the c code (shutdow)? I am in a similar situation with winnt4, where I want to logof and shutdown from within the program by calling a function. I have labview 6i and I do not have any compilers.
Parviz
(3,288 Views)
