LabWindows/CVI
single pulse output on USB-6212 PFI
I am trying to generate a single pulse output on one of the PFI I/O lines on a USB-6212.
How do I go about creating the task?  The pulse witdh is 100ms.
Also, how do I trigger from one I/O line to start another I/O pulse?
(3,199 Views)
Hello johnswan,
The first thing you need to do is make sure that you have the NI-DAQmx driver installed.  This should've came with your device, but if not you can download it from ni.com/updates.  After the driver is installed it will add examples for LabWindows CVI.  In LabWindows CVI you can go to Help » Find Examples to open the NI Example Finder and then navigate to Hardware Input and Output » DAQmx » Generating Digital Pulses.  There is a DigPulse.prj which will show you how to create a digital pulse with a specific pulse width.  There is also a project called DigPulseTrain-Cont-DigStart.prj that you can look at to see how to implement a digital start trigger.  Take a look at these and let me know if you have any additional questions.
(3,175 Views)
