06-19-2009 06:29 AM
hi,
i have a problem with the snap of image in cvi.
I can open und can read the attribute from the camera over firewire.
But i can not read a pic.
Can someone send me a example?
By
wolf4124
06-22-2009 02:54 AM
Hey Wolf,
if you installed the vision acquisition software please be sure that you checkmark the CVI support.
Activate the software in the license manager.
Test the camera in MAX and take a snap or grap and press the save button.
http://zone.ni.com/devzone/cda/tut/p/id/2977
Finaly switch to the example finder in cvi and open under hardware input output /Imaqdx or legacy the snap example.
Kind regards,
Elmar
06-22-2009 05:11 AM
hello Elmar,
i found a example for simple snap.
But i need the funktion "imaq1394SnapImage" for it.
I can't find the funktion in my c-files.
Kind regards,
wolf4124
06-22-2009 06:49 AM
Hey Wolf,
as i posted before please be sure that you install support for your software.
After the installation and activation you will find 1394 snap examples in your CVI example finder.
It looks similar to the printscreen in the attachment.
Kind regards,
Elmar
06-23-2009 03:49 AM
Hey Wolf,
if you are able to open the snap example you will find also the 1394 snap function.
Because it exist only one function for snap.
But the snap function name could change if you select the imaqdx driver in MAX instead of the legacy driver.
Kind regards,
Elmar
